Re: 300U 12v Conversion Done!!
Posted by JayWalt on March 03, 2007 at 05:53:27 from (70.226.7.125):
In Reply to: Re: 300U 12v Conversion Done!! posted by Armand Tatro on March 03, 2007 at 04:55:17:
well, heres the thing. Nobody makes an inline 50amp fuse holder. I'd have to go with a mounted fixture for that, and it first wasnt in the budget, and second there is not much room. The fusible link is only 2.79. It also just fuses the main alternator output to the battery for charging. If my system is pulling more then 55amps, something is probably wrong besides the fusible link. Ideally I would have likes to use a fuse, but that is also one more bad connection to have problems with. Cars have used them for YEARS!! mind you they are usually in spots that arent easily accessible. To each his own I guess. Simplest and Cheapest route led to this =)
