Re: Not real on ebay?
Posted by JIM MOSIER on March 04, 2007 at 06:09:37 from (65.211.143.114):
In Reply to: Re: Not real on ebay? posted by sflem849 on March 04, 2007 at 05:52:50:
HI SCOTT, I ONLY HAVE THE 1 PIC THAT I TOOK OF THE CABLE OPERATED 2 SPEED. WITH THE BLACK FRAME IT IS HARD TO SEE. AND WITH LESS THAN 12 HOURS I CAN'T DO ANY ADDING OR CHANGING I MY DESCRIPTION.THE WESTERN PART I PUT IN WAS JUST WHAT A COUPLE OF GUYS TOLD ME, SO I REALLY CAN'T SAY ON THAT END, BUT THE 2-SPEED WORKS GREAT AND IT IS A VERY SOLID OLD UGLY TRACTOR, EVEN THE SEAT BUSHINGS ARE TIGHT, THE MAN HAD MORE BLACK THEN HE DID RED AND THAT IS WHY IT IS PAINTED LIKE THAT AND HE WANTED TO BE DIFFRENT, IF YOU HAVE ANY MORE QUESTIONS LET ME KNOW.
THANKS JIM
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
