Re: Model M with a miss
Posted by RustyFarmall on March 04, 2007 at 10:21:05 from (66.43.253.11):
In Reply to: Model M with a miss posted by hickoryvalleybob on March 04, 2007 at 09:53:00:
Playing with the choke rod can mask lots of problems. Most likely the miss has nothing to do with the carburetor. You might have sticking valves, or maybe just improperly adjusted valves. The miss could be a result of worn distributor parts, which is probably the culprit. Could be as simple as faulty spark plugs.
