Re: Power steering valve thingy
Posted by T.B.W. on March 06, 2007 at 07:06:14 from (4.248.243.172):
In Reply to: Power steering valve thingy posted by markloff on March 05, 2007 at 17:04:11:
The Hyd. line from your live pump goes to a priority valve that sends about 3 gallon per min. to the power steering. You will need a return line fron the power steering motor to the tank. Your pump should be about 12 gal per min so that leaves 9 to run the loader or 3 point. I have live power on my M with a loader and the steering and the loader work at the same time. I got my parts at Steelwheelranch.com. Check with mike there and he will tell what you need. you will also need some Hyd. lines to complete everything. I got them at tractor supply. Plan to spend about $700 to make it all work. I had the pump that ran off the generator belt, but that didn"t work very well, always weak. Tom
