Re: Water in steering gear?
Posted by chadd on March 07, 2007 at 04:31:35 from (155.92.32.206):
In Reply to: Re: Water in steering gear? posted by Glen Wentzell on March 06, 2007 at 11:47:27:
OK. . . That definitely sounds like a steering box problem. For the steering wheel to start screwing out of the dash, something broke in there. There are two thrust bearings on the steering shaft to keep it located properly. It is possible one or both of those bearings died and now the shaft is able to move in and out. Good luck.
