Re: Water in steering gear?
Posted by Glen Wentzell on March 06, 2007 at 11:47:27 from (142.177.8.29):
In Reply to: Re: Water in steering gear? posted by chadd on March 06, 2007 at 09:43:07:
Hi,,and thanks!.I looked today at what i think is the steering pump,,,in front to the left(sitting on tractor).It seems to run the whole hydrolic system,,even the back drawbar.Now..when i turned the steering wheel..the wheel seemed to turn upwards like it was unscrewing out of the dash of the tractor,untill it went tight to turn the wheels.Turn it the other way,,and the steering wheel turns downwards ...as i say just as though it was screwing and unscrewing in and out from the dash..Seems that there might be something not catching quite right in there dosnt it?
Glen
