Re: Farmall A Zenith Carb questions
Posted by Chad from Michigan on March 07, 2007 at 07:05:12 from (152.72.151.71):
In Reply to: Farmall A Zenith Carb questions posted by Chad from Michigan on March 07, 2007 at 06:24:28:
I didn't buy a replacement kit. The only bad thing most of the time is the gasket. I took and soaked the carb it looks new. Took out each jet made sure it was clean completly tore it down and used compressed air to blow it out.
I need to replace the needle and seat it wont stop the gas. Even with the sediment bulb off it leaks as well so I have a coffee can under the carb right now.
I get no difference in engine performance adjusting that screw and it seems like you would see something or hear the engine? am I worng on that?
On my cub Carb float I have settings for both directions on the float amount of drop and the closed postion.
Chad
