Re: farmall f-12 f-14 frame weights
Posted by ET on March 08, 2007 at 04:41:12 from (134.179.104.132):
In Reply to: Re: farmall f-12 f-14 frame weights posted by John M on March 07, 2007 at 18:16:50:
I have a F12 with a wide front on it and a No. 90 plow on back. I had to use a set of front weights to off set the suck of the plow as you lift it out of the ground. The rectangular weights are necessary with a wide front because the front axel would hit the triangle shaped ones when the axel pivots all the way to one side or the other.
