Re: I-4/O-4/W-4 Engine removal
Posted by John M on March 10, 2007 at 05:23:42 from (204.116.130.100):
In Reply to: Re: I-4/O-4/W-4 Engine removal posted by L.C. Gray on March 09, 2007 at 21:46:19:
The 4 joint bolt could also have some wear on them making them hard to get out. I just used a wrench and some WD40 to work them out. WhenI pulled my engine,I got it just high enough to slide the shaft out.
