560 Diesel Hard to start
Posted by Rex Best on March 10, 2007 at 19:50:20 from (69.148.249.196):
Hello guys! I have a 560 diesel that will not start with the starter even after warming the glow plugs for 3-4 minutes. We can pull start it and it will run good for a while. Eventually it will try to die out. If I reduce the throttle and then try to give it full throttle it will sometimes just go ahead and die. Father-in-law says the injector pump is sticking and it is very tricky to remove and repair ourselves. Any suggestions would be helpful. Thanks
