Re: 504 torque amp.
Posted by D Slater on March 11, 2007 at 13:12:08 from (205.188.116.133):
In Reply to: 504 torque amp. posted by makin'hay on March 11, 2007 at 11:51:30:
If no speed change when you pull lever back the T/A clutch is not disengaging for some reason. Also a outside chance the planet gears locked up for some reason,but I doubt thats it.
