Re: freeze plugs in shift tower
Posted by El Toro on March 11, 2007 at 18:23:18 from (64.12.116.71):
In Reply to: freeze plugs in shift tower posted by JOE-ILLINOIS on March 11, 2007 at 17:48:31:
Put some dental cement on them. I would use just a little dab on them in case you need to remove them. Hal
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
