Farmall Tractors Discussion Board
Re: Moving F-12 wheels
Posted by Brian '35 F12 on April 25, 1999 at 17:00:13:
In Reply to: Moving F-12 wheels posted by Jason on April 25, 1999 at 06:11:32:
Jason,
I had to do this to mine to get them off....
First my clamp bolts came loose WAY easier then I thought they would. So if you haven't tried them try it you'll only be out a little time. After those are either loose or out I soaked my jack screws with liquid wrench(I also sprayed it on the axel shaft where the rim is to aid in loosening up the whole assembly) then I would go out before I went to work and smacked to tops of the screws with a hammer then sprayed 'em again three days later presto! they came loose. I didn't mind the three days, I had plenty of other things to tear down. Also try soaking your clamp bolts the same way. Hope it helps, I hate to see the smoke wrench come out if it can be avoided..
Good luck, Brian
Post a Followup
: Re: Re: Moving F-12 wheels
