Farmall Tractors Discussion Board
Re: Re: Moving F-12 wheels
Posted by DAL'S HOME FOR ABUSED FARMALLS on May 08, 1999 at 19:23:52:
In Reply to: Re: Moving F-12 wheels posted by Brian '35 F12 on April 25, 1999 at 17:00:13:
IF IT RUNS OR CAN BE PULLED, LOOSEN ANY OF THE NUTS YOU CAN AND DRIVE OVER SOME ROUGH GROUND. I HAVE FOUND THAT THE CLAMP BOLTS HAVE TO BE REMOVED BEFORE YOU CAN GET AT THOSE SQUARE HEADED SPREADER BOLTS. I HAVE HAD PRETTY GOOD LUCK WITH MY 3/4 BREAKER BAR AND 3 FOOT EXTENSION. AS POINTED OUT IN THE PRIOR NOTE, TIME IS YOUR BEST FRIEND.
Post a Followup
: Re: Re: Re: Moving F-12 wheels
