Farmall Tractors Discussion Board
Re: Farmall Super M Exhaust Manifold Getting Cherry Hot!!!!
Posted by RKS on April 25, 1999 at 18:30:20:
In Reply to: Farmall Super M Exhaust Manifold Getting Cherry Hot!!!! posted by Jeff Norton on April 25, 1999 at 18:14:17:
suspect radiator, water pump, or blocked "water jackets" in the block. The passages in the block my be full of rust and sediment, reducing the cooling capacity of the cooling system. If you have a temp guage, it should have indicated over 220, maybe a lot over.
Post a Followup
: Re: Re: Farmall Super M Exhaust Manifold Getting Cherry Hot!!!!
