Re: International 1086 draft/hydraulic problems
Posted by formerly ny bill on March 12, 2007 at 18:32:14 from (66.24.240.172):
In Reply to: International 1086 draft/hydraulic problems posted by gene@p.g.,va on March 12, 2007 at 17:22:56:
is the top link adjusted so the points will still draw the subsoiler down as it gets deeper? might try shortening the top link to see if it helps. also, there is a slot in the linkage under the platform to adjust the travel on the draft and 3pt levers. you might get more down draft if the lever could be changed. my 1086 will sink the plow until it stalls if the draft is set too heavy.
