Re: PTO on My Cub
Posted by Roger46 on March 13, 2007 at 19:17:38 from (69.58.159.17):
In Reply to: Re: PTO on My Cub posted by Jim Becker on March 13, 2007 at 07:47:14:
I read through the Cub PTO failures and it was interesting in that it discussed my problem on my Cub. The previous mechanic who worked on my Cub had installed the transmission input shaft seal backwards creating about 1/4 inch of play in the transmission shaft which connects to the PTO spline. With this seal installed wrong, the transmission shaft slides forward and the PTO will bearly ingage and ends up grinding the splines off the transmission shaft. I ended up having to replace the transmission shaft and putting the seal in the correct way to solve the problem. By the way, the seal installation is backwards from what you would think it would be looking at it casually. Roger
