Re: 656D Running Rough
Posted by South Texas on March 14, 2007 at 13:58:49 from (208.128.48.13):
In Reply to: Re: 656D Running Rough posted by Allan In NE on March 14, 2007 at 12:06:48:
Allan - It does indeed run normal at low RPM without load, then gets choppy at wide open with grey smoke, you might describe it as a surge. It does not miss "all the time" just all the time at high rpm.
I had a retired diesel mechanic overhaul the pump, I have alot of faith in him but it could be he got something wrong, he is pushing 85 years old.
I have recently changed the fuel filters and have not found any water in the fuel. Any suggestions you can give me would be greatly appreciated, I'll try about anything.
Thanks-
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
