Re: 656D Running Rough
Posted by Hugh Mackay on March 14, 2007 at 14:43:30 from (209.226.106.71):
In Reply to: Re: 656D Running Rough posted by South Texas on March 14, 2007 at 13:58:49:
ST: Diesel pump rebuilding is not a back yard hobby of a retired mechanic. Doesn't matter how good he once was. It takes sophisticated, expensive equipment, and it takes a very clean envoirnment.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
