Farmall Tractors Discussion Board
Re: Re: battery cables
Posted by Phil Auten on April 26, 1999 at 04:44:14:
In Reply to: Re: battery cables posted by RKS on April 25, 1999 at 16:54:55:
Joe,
I've even seen the correct 2Ga. cables in stock at Wal-Mart. Just make sure the cables are at least 2Ga. wire so there is no "lost" voltage before the starter. You also might take this opportunity to remove the starter and clean the mating surfaces well and cover them with a thin coat of grease to keep the ground good for the starter. Lots of hard starting problems in 6V systems are caused by bad connections. Now is a good time to make sure all of the connections in the circuit are clean and bright and stay that way.
Phil
Post a Followup
: Re: Re: Re: battery cables
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
