Farmall Tractors Discussion Board
Re: Re: Re: battery cables
Posted by Rick K on April 26, 1999 at 09:39:53:
In Reply to: Re: Re: battery cables posted by Phil Auten on April 26, 1999 at 04:44:14:
Better than grease is anti-seize compound. It is basically a grease with a variety of metal particles in it. The grease will keep out oxygen and other things, which helps prevent corrosion. At the same time, the added metal particles will insure a good electrical connection. Electrical current passing through a poor connection provides the energy that accelerates corrosion.
Post a Followup
: Re: Re: Re: Re: battery cables
