Farmall Tractors Discussion Board
Re: Farmall Super M Exhaust Manifold Getting Cherry Hot!!!!
Posted by The Red on April 26, 1999 at 04:53:35:
In Reply to: Farmall Super M Exhaust Manifold Getting Cherry Hot!!!! posted by Jeff Norton on April 25, 1999 at 18:14:17:
It depends on what you define as under load. If you are discing or pulling a chisel tooth, I have seen the manifolds get cherry hot with the governor being fully opened. If its getting red from simply going up a hill or pulling hoppers, then I suspect overheating. Does your water temp. gauge work? If not, then I would invest in a new thermostat. My 51H had the original thermostat in it and it was stuck closed. Who knows how much that machine ran too hot.
Post a Followup
: Re: Re: Farmall Super M Exhaust Manifold Getting Cherry Hot!!!!
