Re: Seized farmall M
Posted by Ron in Nebr on March 16, 2007 at 19:07:07 from (66.252.113.99):
In Reply to: Seized farmall M posted by sonny IH on March 16, 2007 at 17:33:19:
One other thing you might try after letting it sit with the PB Blaster in the cylinders for awhile is, remove the starter and get a big pry bar and, using the ring gear teeth on the flywheel to pry on(use common sense here, don't break the teeth off), try to get the engine to turn backwards(counterclockwise looking at it from the front). An old-time IH mechanic who's been into old engines all his life told me this, and using this method I had a 650D I bought unstuck in one afternoon. Your results may vary!!!
