Re: 504 rough running, distributor/timing??
Posted by Jossette on March 17, 2007 at 05:55:28 from (216.114.223.177):
In Reply to: 504 rough running, distributor/timing?? posted by RUSTY in TX on March 17, 2007 at 01:09:03:
check tdc and then check the gap in the points to .020
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
