Re: 504 rough running, distributor/timing??
Posted by Roger Mills on March 17, 2007 at 06:45:34 from (71.213.68.215):
In Reply to: 504 rough running, distributor/timing?? posted by RUSTY in TX on March 17, 2007 at 01:09:03:
You could have the drive gear off one tooth. Find #1 compression (finger in the plug hole trick) then line up tdc and the rotor should point to #1 and points should just be opening. If so you are close. Rough idle could be mixture and same for high end--check carb and fuel flow, might be starving at high RPM.
