Re: 45 A with water pump and dip stick
Posted by Roger Mills on March 18, 2007 at 07:52:09 from (71.213.68.215):
In Reply to: 45 A with water pump and dip stick posted by Chad from Michigan on March 17, 2007 at 18:22:28:
If you pull the head, and maybe you should, the head gasket is different when the water pump is installed and it may not be correct if the pump was added. The one for the thermosiphon cooling had water passages that matched the engine and the one for the water pump has round holes. They help cool the rear cylinders by restricting the flow around the front of the block because it acts like a bypass if the holes are too big.
