Re: W-6,s
Posted by Kirk In Ks, on March 18, 2007 at 08:13:18 from (65.171.117.3):
In Reply to: Re: W-6,s posted by chadd on March 17, 2007 at 21:48:03:
Hi Chadd,
It,s Kirk,
I was going over your letter, and you are right on about alll this stuff,
I was seeing that the top hose was warm to the touch and vibrating a little?
So,,, that was puzzeling me as to what the pump was doing?
I was in a parade last summer, and all was well ,except when I went to drive it home from the yard it was in where the plow day was,
I got it started, and drove it down the road to the highway,
It started to labor, and the pump wes hot and smoking,
I shut it down right there chadd,
Tried to start it again, it was turning hard,
So I later put some fluid in the res tank, and the thing started right up no problem,maybe low on fluid?
So,,, I started down the back road to my place,
and I was halfway there and fluid or oil one or the other was running out the bottom under the clutch housing,
I stopped again, and this guy I know towed me home from there on to my place,
And there it has sat till now wondering what was wrong with it,
Chadd, I thought you filled the oil in the front, and the hyd fluid in to the res tank in back?
Maybe Ill open that tower and take a look at it to see if the ball and spring are working?
Ill be back later ok,
Kirk,
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
