Re: W-6,s
Posted by chadd on March 19, 2007 at 05:10:59 from (155.92.32.22):
In Reply to: Re: W-6,s posted by Kirk In Ks, on March 18, 2007 at 08:13:18:
If the pump got hot enough to start smoking, it is a fair assumption that it is toast. The pump mounted on the distributor drive is a gear pump with two steel gears inside an aluminum housing. With no oil, it will score the housing up very bad, and will burn the seals out of it or quickly wear down the shafts where the seals touch. You will need to get the pump rebuilt. You add engine oil by removing the cast iron cap with the two tabs 180 degrees apart by turning it counter-clockwise. The cap is located on top of the front of the distributor drive. Open the test plug by screwing the top diamond shaped knob counterclockwise. When oil drips out slowly, the crankcase is full and you should stop adding oil and close the test plug by screwing it clockwise. The hydraulic fluid should be added to the reservoir, which is the big cylindrical tank, by removing the plug with the T-handle on the upper left side of the tank. The transmission and differential are filled through the pipe plug mounted on the platform right behind the steering box. There is a check plug on the left hand side of the tractor's transmission that is used to see if it is low or not. If it doesn't come out of the hole the plug was in, it is low. Have you drained the engine oil yet? How much came out? If you drained several (4 or more) gallons out of the engine crankcase and it smelled like hydraulic fluid, your pump is shot. That means no matter how much oil you add, it will continue to dump it into the engine crankcase past the bad seals and dilute the engine oil until it leaks out the rear main oil seal on the crankshaft again or the pump finally locks up.
Home
| Forums
Today's Featured Article -
The Engine Rebuild Kit - by Curtis Von Fange. I always liked engine rebuild kits. They have all the replacement parts for overhauling an engine without going to the store to get gaskets, special measuring tools, or miscellaneous parts. They come neatly packaged, clean and tidy. But it's important not to let that packaging lull you into a false sense of security. The appearance of matching sleeves, pistons, rings, and bearings can cause frustration and agony if not properly measured and installed in a workshop environment. Following c
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
