F12/14 Manifold Gasket
Posted by Fawteen on March 18, 2007 at 11:03:33 from (66.181.126.116):
Doing a little update on a 10 year old rebuild of my F14. One part of the project is to replace the leaking manifold gasket. Got the manifold off this afternoon, and 3 out of four of the exhaust ports had chunks blown right out of the gasket.
When I rebuilt the motor, I used the one-piece fiber gasket that came with the kit. New manifold, new head, new studs, brass nuts, all torqued down good and rechecked after a couple of heat cycles on the engine. Ordered a replacement gasket from Rice Equipment, same deal, plain fiber gasket.
Dunno if something is warped or if I just didn't reef it down tight enough, but all the intake ports looked fine.
Is there a heavier duty gasket available? Maybe something with metal crush rings around the exhaust ports?
