IH 350 Hydraulic update
Posted by Jrry on March 19, 2007 at 07:33:40 from (205.144.236.179):
I posted last week about problems with my hydraulics. I was adding fluid to the transmission thinking it was a common reservoir for the hydraulics and transmission. Hugh and others straightened me out on this. I added fluid to the hydraulic reservoir this weekend and the hydraulics began to work. The fast hitch seems to work fine. The loader now works but not correctly. I pull back on the handle and it will lift about a foot. Pull back on the handle again and it will lift another foot and stop. I can keep doing this and it gets higher but why will it not raise smoothly? I may be still low on fluid but not sure since I'm not sure how to know what level is needed. I had to remove a hose pipe on top of hydraulic system to add the fluid. thanks again for any suggustions.
