Re: How can I get my 706 Diesel unstuck?
Posted by L Mack on March 19, 2007 at 16:43:13 from (68.157.139.93):
In Reply to: How can I get my 706 Diesel unstuck? posted by ReddHeadd on March 19, 2007 at 16:24:55:
Disels do not often stick like gasoline tractors unless you leave it out in the rain without a weather cap on the exhaust. Before you put too much stress on the engin and break a crank shaft, you might want to check for hydraulic lock. That occurs when the cylinder gets full of liquid. Putting oil or diesel in the exhaust will only oil one or two cylinders and is sure to cause hydraulic lock. You have to remove the injectors to turn it over or otherwise pull the head. Try the injectors first. If it will turn, spin it until all the liquid is out. If if will not turn, use a mixture of kerosene and transmision oil (the ratio is on you) and squirt it into the injector holes. Let it sit for a few days and try rocking the tractor in high gear. After putting the oil into the cylinders, you will have to spin the excess out with the starter before replacing the injectors. Have them pointed in a direction that does not matter since it will be messy.
Home
| Forums
Today's Featured Article -
Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
