Re: C113 Piston Pin Bushings/Rods Fit
Posted by Roger46 on March 19, 2007 at 19:38:16 from (69.58.159.62):
In Reply to: C113 Piston Pin Bushings/Rods Fit posted by CSR on March 19, 2007 at 03:03:44:
As the others have said, this is something you need to have done at a machine shop with the correct setup. While they are at it for a few dollars more they can check the rods to make sure they are not bent and if so can rebore the rod bearings to get everything in alignment. I just had mine done on my Farmall 350 diesel engine rebuild. Roger
