Super C - Engine Help (Governor?)
Posted by J Clark on March 19, 2007 at 20:39:47 from (69.214.3.31):
I have been working on my grandfathers Super C. About a month ago it suddenly stopped starting and I did a complete tune up/troubleshoot including: new wiring, new battery, disassembly and cleaning of carb, adjusting valves, checked pistons, installed new plugs, pulled and checked starter, installed new starter switch and 1 gauge cables, changed oil, new filter, checked compression, installed new rotor/cap/wires, adjusted timing and confirmed firing sequence… I am not much of a mechanic this is why it took me most of a month to accomplish the above. I think I covered the basics (air, spark, fuel, compression, etc) and all this maintenance resulted in a significant improvement in the tractors idle and starting (starts on 2nd crank every time now) BUT I can not get the tractor to throttle up. The throttle lever has no effect and the engine stays at idle. From what I can determine the carburetor is connected to a device at the front of the engine block. Since the owners Manuel does not detail or label the device I have assumed through elimination that it must be the governor? When the tractor is running I can manually push this connecting rod from the carburetor and it will rev up the engine, but the throttle lever still does nothing. Throttle cables are good and the throttle lever does move the lever on the governor. I know nothing about governors except that it looks complicated and appears to require the removal of the radiator to work on it. I am aware of my mechanical limitations and this seems like a lot of work. Is this the correct course of action? Are there any adjustments on the governor? Are there any typical weak/breakable parts or springs inside that are meant to be worn out/replaced? I really want to keep this machine running as it is a 3rd generation machine. Any help to this amateur would be appreciated.
Home
| Forums
Today's Featured Article -
The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
