Re: Super C - Engine Help (Governor?)
Posted by gene bender on March 20, 2007 at 04:20:41 from (67.55.226.214):
In Reply to: Super C - Engine Help (Governor?) posted by J Clark on March 19, 2007 at 20:39:47:
Before you remove the gov housing to replace the spring which appears to be broken get the I&T manual as it will show the correct adjustments. You probably will have to remove the throttle linkage going to the carb from the gov as the clevis is probably froze and you need the threads to move easy for the adjustment. Be careful removing the gov housing so as not to move the gear as it will get things out of time. Mite want to rebush the input lever on the housing too.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
