Re: Starting Crank
Posted by Will Sick on March 19, 2007 at 22:37:28 from (69.66.140.43):
In Reply to: Starting Crank posted by Gary Puckett on March 19, 2007 at 19:24:53:
There is no difference between the H and M crank. Both have a 3/4 inch opening. The earlier H's and m's had the spinner handle as quite a few of those came out with no electric starter. I don't know what year they changed. The later Farmalls had a cranks mostly to turn the engine for valve adjustment and timing.
