Good news/Bad news!!
Posted by Roger Mills on March 20, 2007 at 08:19:45 from (71.213.68.215):
First tractor show around here this year and I took my A. It was at a park about two miles away so I drove the tractor rather than loading it. Good news-only red one there-its green country. Lots of folks had never seen what one guy called a 'side saddle' tractor. Bad news-front seal leaks bad and I had oil running down the RH side of the block from the head gasket between #3 and #4. To this point I had only driven it around the yard. It sat most of the winter snowed in. Good news-all gears are quiet and so is the diff, (slight whine but no clanks or clunks). Bad news-forgot that the brakes barely work. Good news-it is flat roads and only 3 stops. Bad news-one front rim is bent. Good news-oil pressure mid scale at idle when hot. Bad news-governor output shaft leaking oil. All in All-a great time and I'm glad I went-so what if I have to pull the whole front of the tractor apart.
