Re: magneto spark
Posted by Roger Mills on March 21, 2007 at 05:44:43 from (71.213.68.215):
In Reply to: magneto spark posted by javan on March 20, 2007 at 18:25:50:
Were you using the starter to crank it over? Sometimes the impulse coupler will dis-engage early. Try the had crank and listen for the impulse to snap-if you hear it AND the spark is still that weak try a new condenser and points, if that doesn't help the coil is probably arcing internally.
