Re: Plugged filter again, and again, and again, 4
Posted by Janicholson on March 21, 2007 at 11:43:39 from (199.17.6.122):
In Reply to: Re: Plugged filter again, and again, and again, 4 posted by Gary in Mozarks on March 21, 2007 at 10:52:46:
Well drilling companies and others (google wire mesh) will have it in bulk. (I do not know the physical layout of a 560) I would find a way to put a mesh screen around the intake with as much surface area as possible. Support of the inside of the screen is important (a spring or wire cage to prevent collapse would be good) brass screen solders well, and can make good intake filters.
Another thought is to run a small (mimi pump (little giant) with tubes going to a cone shaped milk filter in a bucket. Draw all the fluid out through the filter into the bucket, then pour it back in, run the tractor a bit, then do it again. In three or four runs the junk may be all out. The only worst case is the material may continue to flake/degrade off the surfaces. Good luck, JimN
