Re: 1466 engine
Posted by Owen Aaland on March 21, 2007 at 14:19:49 from (65.165.246.14):
In Reply to: Re: 1466 engine posted by ohjeffoh on March 21, 2007 at 10:25:13:
Make sure you get the newer elbow and not one off of an older engine. Original elbows had a separate orfice pressed into the elbow. Later ones had the orfice drilled in a solid elbow. Check to be sure the orfice is not still in the pump.
The original style could come lose and get back into the pump. When the pump is is start position the loose piece could get under the fuel control sleeve and when the engine starts the governor cannot move the sleeve down to control the engine speed so the engine revs until the valves get bent bouncing off pistons or the block gets ventilated. Either result can ruin your day.
Today's Featured Article - An AC Model M Crawler - by Anthony West. Neil Atkins is a man in his late thirties, a mild and patient character who talks fondly of his farming heritage. He farms around a hundred and fifty acres of arable land, in a village called Southam, located just outside Leamington Spa in Warwickshire. The soil is a rich dark brown and is well looked after. unlike some areas in the midlands it is also fairly flat, broken only by hedgerows and the occasional valley and brook. A copse of wildbreaking silver birch and oak trees surround the top si ... [Read Article]
Latest Ad: Variable pulley for case 1530 skid loader [More Ads]
