51 Cub - proper direction of oil seals
Posted by Kurt in Va Beach on March 21, 2007 at 18:50:02 from (4.84.16.93):
Hi all, I have kind of a dumb question. Which way is the proper direction for the front / rear engine seals and also others like those that go for the distributor and such. I use to know, but can't remember. Can't remember if small spring that is behind seal edge goes towards oil or out. I thought it was towards. thanks!!
Kurt
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
