Re: Hydraulic Diverter
Posted by Keith-OR on March 21, 2007 at 23:09:11 from (207.200.116.73):
In Reply to: Hydraulic Diverter posted by ToddL on March 21, 2007 at 16:04:50:
Todd, not sure exactly which flow control valve you are using. Why are you using a flow control valve(hydraulic diverter)? If you are using it to run more than one hydraulic system from one pump, you have it plumbed wrong. Primary pressure go directly to the diverter(flow control valve)and CF should be hooked to your steering. EX should go to your other hydraulic system.
Also have no idea which tractor you are working with. really need more info
Keith & Shawn
