Re: C135 piston sleeve question
Posted by georgeky on March 22, 2007 at 06:41:54 from (205.188.116.142):
In Reply to: C135 piston sleeve question posted by vinnyJimbo on March 22, 2007 at 06:23:59:
That O ring you have should be for bottom of sleeve. There are none at the top. Without the seal in the bottom it will leak water into crank case. The head gasket seals the top.
