C135 piston sleeve question
Posted by vinnyJimbo on March 22, 2007 at 06:23:59 from (129.33.1.37):
Rebuilding IH C135. Kit sleeves has a groove and O-ring for top of sleeve none for bottom. Block has no grooves and old sleeves have no O rings or grooves. Engine is later serial number. Does this sound right ? Is the press fit on the bottom of the new sleeve good enough to keep water from the jacket out of the oil in the lower crank case ?
