Re: C135 piston sleeve question
Posted by Roger Mills on March 22, 2007 at 06:58:11 from (71.37.118.105):
In Reply to: C135 piston sleeve question posted by vinnyJimbo on March 22, 2007 at 06:23:59:
George is right, the o-rings go at the bottom and there are supposed to be grooves that the o-rings go in and the sleeves are a stiff push fit. If your block doesn't have any grooves then the real question is "why not". Was it bored out for some reason? Check again and measure the block bore. Hope you have the manuals.
