Re: planter for SuperA
Posted by georgeky on March 22, 2007 at 12:56:43 from (64.12.116.71):
In Reply to: Re: planter for SuperA posted by CharlieSeal on March 22, 2007 at 11:39:35:
Charlie all seed plates are not the same. Some are thicker than others. The thinner ones require a filler ring to take up slack, they come in 4 or 5 different thicknesses. They fit under the plates to raise plate so this dosen't happen. If you will take the plate out and look on it there will be a number. If you can tell me the number I can tell you which filler ring you need. If you will find a part number on the pieces you need I think I do have them. I may also have a extra set of plates.
