Re: Farmall C Starter Question
Posted by Kenneth Fass on March 23, 2007 at 10:00:05 from (64.73.36.192):
In Reply to: Re: Farmall C Starter Question posted by MN Scott on March 23, 2007 at 09:39:23:
MN Scott,
This sounds right. I guess I will end up taking it to a starter shop then. Unless I can come up with another idea.
Actually now that I think of it, I may just drill 2 more holes in the saddle switch base so I can permanently attach it "moved forward" slightly. This should allow enough additional travel on the switch to make contact....
Hey I think this might work!
