Wet Stacking UD-9
Posted by Mike in Shendoah Valley on March 23, 2007 at 18:56:10 from (71.171.70.26):
A very good friend of mine was using his power unit on a sawmill when it suddenly started blowing liquid engine oil out the muffler.It still runs smooth with no miss or anything.Injection pump oil level is ok. engine oil is not overfull and is not diluted. NO blowby-even loosened the oil filler cap while running-no pressure buildup.Vent is clear. Oil is all over everything-the flat belt,part of the carrage,etc. Not much smoke either,just lots of oil.So whats up? Is there any thing that could happen in side the valve cover that might come loose causing this?
