Re: Valve Clearance On WD6
Posted by Charles McNelly III on March 24, 2007 at 07:44:21 from (65.148.221.233):
In Reply to: Valve Clearance On WD6 posted by Tom Erth on March 24, 2007 at 05:15:48:
Hi Tom, According to my service manual, there set at .017 hot. When you set these up the first time, I would recommend setting them to .020 cold. They should be close when engine is at normal operation temp. The firing order is 1,3,4,2. Turn the engine over to top dead center of the compression stroke for each cylinder to set.
Good Luck, there neat tractors.
Charles
