Re: Valve Clearance On WD6
Posted by El Toro on March 24, 2007 at 08:00:58 from (205.188.116.142):
In Reply to: Valve Clearance On WD6 posted by Tom Erth on March 24, 2007 at 05:15:48:
You can adjust valves 1,2,3 & 5 when No1 piston is at TDC, then adjust valves 4,6,7 & 8 when No4 piston is at TDC. That's counting from the radiator to the back. Hal
