Re: td9 crawler problume
Posted by Doc Larry on March 25, 2007 at 04:50:00 from (216.146.101.227):
In Reply to: td9 crawler problume posted by MDerrick on March 24, 2007 at 15:05:19:
I can"t quite tell from you comments if you have no compression, or low compression. If you have low compression, I"d take another look at the compression release mechanism, if it"s working, check to see if the starting valves are stuck open (a common problem). The compression release cams push down on some caps (inverted cups) that sit on top of the starting valve stems. If any of the caps aren"t moving up and down as you work the compression release, those valves are stuck open, and will reduce your compression to the gas engine ratio of 6:1 or something like that.
